Best Winch for the Buck?
Alright I'm not sure if this is the best place for this tread but it makes sense to me to put it here. Anyways I'mthinking it's about time to invest in a Winch. Was wondering if you guys & gals could help me make an informed choice. As the title reads...post up pics and details of what you all are running and any draw backs/facts that you might feel are important when considering a winch. Last thing I want to do is regret this mod.
As always buy quality. You do not want a cheap winch when you get stuck. If you have to pay someone to pull you out then you will not have saved a dime much less your time and pride.
Milemarker makes a good product but can't beat Warn. Also recreational winches are rated for the last wrap and slowest speed before stall. So don't be afraid to buy a 12k winch. The only sacrafice for more power is line pull speed and I don't believe you will be in rock crawling race.
Don't forget the accessories like snatch block, straps, etc. A snatch block is worth its weight in gold but you have to have the riggings to go with it.
I've got the smittybilt xrc8 on my unlimited and it does just fine. They changed a few things on it in the last year or two. It has done it's job just fine for me. and for $299 shipped it can't be beat. although it might be more up where you are. When I was researching this I found that the people that had warns recommended not to go cheap and spend the money on the warn. I also found that most who had the smittybilt or milemarker (exact same winch just a different sticker) said they were great.
Not again
Smittybilt SUCKS - works some times - not all the time. Does not work after a watercrossing...??Maybe no winch does??? I'd like a winch that will work when fully submerged in muddy water, is that asking too much?
I like the new Mile Marker with solid state instead of solenoid. Allows variable line speed. Thats a HUGE plus. Even slow pull sometimes is too fast.
That being said I bought a Rugged Ridge 10.5k. I just couldnt afford the Mile Marker. I will replace my RR with the MM and move the RR to the rear when I have the money.
I've had warn, ramsey and mile marker winches and I wouldn't hesitate to buy another smittybilt when the time comes.
I've had my smittybilt under water many times (see my avatar) and it has worked flawlessly for 3 years. It has been plowed into mud banks, pulled me through the rocks after breaking an axle and winched a lifted unlimited rubi with no problem. That night we winched for 7 hours straight with 2 other smittybuilt winches and they all preformed great. The biggest problem you are going to have is making sure your battery can handle it.
