JKU map light replacement with brighter LED
I recently picked up a '13 JKU and started replacing all of the interior bulbs with high power LED's (6000k color). This is something I do with all of my vehicles, call it OCD if you will.
My question for you guys is has anybody successfully removed the tungsten colored bulbs located in the rear view mirror and replace them with different ones? I think I read somewhere else that they are soldered into the mirror but I haven't gotten a solid confirmation on that yet.
Thanks.
Thanks.
Heres a link to the Amber ones----> 2 x H16 Yellow LED Bulbs DRL Fog Lights Lamp SMD | eBay
Heres a link to the 6000K ones----> High Power White LED Fog Light Bulbs DRL Lamp 5202 5201 H16 PSX24W | eBay
I currently run the 6000k ones.....to the OP i looked around and didnt see anything for the mirrors....sorry
When u get them there will be 3 tabs on the side if it and there will be 3 slots on ur fog lights housings. These tabs won't all fit. Just get a pair of wire cutters and trip the plastic tabs off. U only need to trim 2 of the 3..pm me if u have any problems. I'll explain it better. Takes 2 sec to mod light bulb
Thanks.
Thanks.
I have ones very similar to them in my 13 and they fit fine. I had to trim a couple of the tabs on the connector, but otherwise plugged in and works fine.
